Dinkbuster
Setting up my shop to paint , got air compressor picked out, what size air line ? 1/2 or 3/8, less air pressure drops with1/2 inch but from what I read 3/8 is more than adequate?
not much info here to go by. no compressor size, nor shop size, nor how you are mounting the pipes or if you are even using pipes. or just running a hose off a compressor which is not good as it will have moisture in it.Setting up my shop to paint , got air compressor picked out, what size air line ? 1/2 or 3/8, less air pressure drops with1/2 inch but from what I read 3/8 is more than adequate?
Is that primer?If your using a 50 foot hose, 3/8" is good. I've got 75 foot and have plenty air to paint lines of parts outside.
Paint guns don't require a lot of CFMs so line size isn't all that important. Conversely, if you have an air operated 3/4" impact tool, it really does. Takes a lot of CFMs to get that sucker to perform....but it gets the intended job done.If your using a 50 foot hose, 3/8" is good. I've got 75 foot and have plenty air to paint lines of parts outside.
Yes, I could see that it was Case sheet metal which is why I asked if it was primer, because I was hoping that it was not going to be the top coat, which should be Desert Sand. But as they say it is his tractor....................................i would say its case yellow on case sheet metal.
Same here.I've been using acrylic paints and hvlp sprayer for the past 10 years and life has been much easier.
Most guys get by just fine with 3/8. Unless you're doing a massive production run or have a really long run from the compressor, the pressure drop isn't going to be your biggest hurdle.Setting up my shop to paint , got air compressor picked out, what size air line ? 1/2 or 3/8, less air pressure drops with1/2 inch but from what I read 3/8 is more than adequate?
Starting in 55 Case tractors were tutone...flambeau red and desert sand colors.Yes, I could see that it was Case sheet metal which is why I asked if it was primer, because I was hoping that it was not going to be the top coat, which should be Desert Sand. But as they say it is his tractor....................................
Sorry, going with the 2stage 5 hp 80 gal undersold Rand from tractor supply, 175 psi, was just going to run a hose no air line , but use an inline dryer and well as a filter regulator on air compressor, that work?not much info here to go by. no compressor size, nor shop size, nor how you are mounting the pipes or if you are even using pipes. or just running a hose off a compressor which is not good as it will have moisture in it.
Shop is small as well, 42 by 36 , but tractors will be parked right next to compressornot much info here to go by. no compressor size, nor shop size, nor how you are mounting the pipes or if you are even using pipes. or just running a hose off a compressor which is not good as it will have moisture in it.
