part numbers
JIM603
I have a 1949 jd mc 3 cyl gas 6volt dozer need part numbers for points, condenser, cap , rotor, spark plugs. Tiered of the junk at tc. if you have napa or something better please help. thanks.
NOT. its a two cylinder man. fyi if you dont take proper care of points they last one minute or less. they also need to be adjusted properly & a whole mess of other things like proper voltage to them, correct plugs, correct wires, not carbon core but solid wire core. proper polarity on coil ( it WILL run both ways just not well) etc. GOOD luck!
Now that you have showed that i was wrough. Yes it is a two cyl. not a 3cyl. So my question is the same. Does someone have the part numbers i need. Thanks.
Jim, I use a lot of Standard Ignition parts as a local auto parts store stocks quite a few and can usually get items he doesn't stock fairly quickly.
ANYHOW, I looked your parts up in the Standard Ignition "Ag and Industrial Ignition" catalog at the shop today and never did get back to the catalog long enough to write the part numbers down.
Will do so tomorrow (hopefully)!
Their "Blue Streak" points have long been some of the best you can buy, I hope they haven't been cheapened like 'most everything else these days!
The Standard Ignition part numbers can be easily crossed to NAPA, Niehoff, or BWD at you favorite auto parts store. For that matter, if the pimply-faced kid behind the counter is willing to dig up their version of the "Ag and Industrial Ignition" catalog, they should be able to help you WITHOUT you needing to bring in any part numbers.
Standard has points, condenser, and rotor, but NO 2 cyl cap. At one time, I knew which 4 cylinder cap would work simply by ignoring 2 nipples, however, that escapes me at the moment.
You shoulden't need the part numbers if you are going to NAPA. Their books will have what you need listed. They will have an el-cheapo version & the good stuff. Stay away from the cheap stuff. Your Deere dealer will have what you need also. Use Autolite 216 plug's.
