Scarboroughseadog
My new TEA20 was not charging its battery, so I took off the 6V dynamo which turned out to be shot. I got it fixed and correctly polarised (positive earth).
I then looked at the rest of the system, and all the parts (battery, regulator, coil, sparks) are 12V except for the dynamo and starter. She works fine, exept for the charging issue. Dynamo to go back on but I beleive:
6V starter will probably last for years before burn out, she starts easily. It sometimes over spins and disengages from the flywheel if she doesnt start- is that beacuse it is spinning fast due to 12V? Only happens when starting a hot engine.
6V dynamo will not charge the 12v battery very effectively, and may get hot trying to charge an empty 12V battery.
Is that right?
Is that right?
