Patient Ground Wasps
showcrop
I was out mowing yesterday doing little places here and there around fields. I had made two passes around one small area, then was backing up across it to go into a corner when I noticed a lot of flies looking very busy in a small area. I paused to see if they might be bees or ground wasps and decided they weren't, and continued to back up. Suddenly there were many of them all around me and I got stung on the back of one hand. I tried to brush them off as I put the tractor in forward, then into a higher gear. I got away and shut it off and stepped off. I got stung four times. I thought that it was pretty forgiving of them to let me drive over them twice, then right next to them before they came after me.
Years ago my grandfather told me to stay on the tractor and don't move a muscle as you drive away and they will target the wheels or something moving. So far so good since he told me that- but I know first hand if you run they can follow you a 1/4 mile and it feels like a .22 gotcha. Have you ever heard them inside a new hay bale? Funny thing, he lived to be 86 and never got stung. He claimed it was his body chemistry. I've seen him pull off his straw hat a big yellow jacket flew out of it.
(quoted from post at 06:07:06 08/04/14) Suggest you use S-O-S tractor for rotary mowing! Easier to shift up in speed for escape! Glad they only got you 4 times!
Dave
I was on my Kubota with Glide shift so it was a quick upshift except for the lack of hands available for both swatting and shifting, LOL.
The mistake was going back, some are small, hard to ID, but anything that even resembles a bunch of the same insects bumbling around, run fer the hills !!! LOL!
I have those in an unused chimney flue, no nest, concealed somewhere though. Act the same way when disturbed, when I saw the first few, got away from the edge and watched, they stay local mostly, go back, you will get nailed most likely.
Years ago, friend I worked for running a D3, had a huge lot job, just clear and grub, and I went at it, mostly done, hit a heavily populated one, lot of them all over, but they mistakenly went for the dozer and not me, I crept away, worked on the other side, when I came back through they had dissipated, open station, OROPS, that would have hurt, they tag you with pheromone, then swarm you.
The little ones, smaller nests and populations, seem to bumble more than find you, I stepped on a young or early nest while trimming, sting was not bad for what they can feel like, not that many around, and not aggressive, don't see those much any more, usually a hole in the grass or along a cut in the soil, I put a cover over the hole to see the traffic back up, they get agitated for a short while, then find a detour and act normal but the traffic does back up initially, funny to watch them deal with it, they always figure out a way to get in.
Worst thing I can think of is white faced hornets, I am very cautious when clearing, got face to face with one of the largest/mature nests I have ever seen, glad I left that bush alone, they nest in the strangest places, basketball size and then some, maybe 2, productive one for sure. Tractor and mower did not bother them, I mowed around the bush, but had I bumped any part of it, hard to even imagine how bad that would have ended, might get away, as if they don't target you, you have a window, linger, you're done for sure.
Years ago when I had the old shop I carried a pipe inside the shop from the iron pile, bumping it on stuff on the way in. Clamped it in the vice and walked away for awhile. When I came back I started cutting the end off with a hack saw and the wasps came pouring out the end of the pipe and chased me out of the shop. I had the same thoughts: Why did they wait so long? Jim
Cleaning up around my dad's place years ago with weed eater. Standing on a 2 foot dirt pile and pulled up a large stem of dock. I was banging the roots to knock off the dirt and didn't see the hole that was next to it . . . until the first one got me on the knee. Before I could move they were all over me. I just walked away swatting wherever I felt a sting. Dropped the weedeater and took off my shirt and walked all the way around the house before they left me alone. Got around 40 stings.
When I'm mowing, I can usually spot them up ahead. A few buzzing in a very local area. Next pass in the area and I'll see a few more, some will swarm around me as I get closer to the nest but I just make sure I'm going pretty fast. After a few passes I'll see a pretty good swarm but I'm usually far enough away so they don't bother me.
A couple of weeks ago found a soccer ball size nest in a low hanging branch of a tree (about 3 ft off the ground). Last weekend, the nest was shredded on the ground and the grass matted down like an animal was there. What kind of animal attacks those things? Skunk?
Also, this past weekend, went into a small shed to get a 3 pt fence unroller I made. After 3 trips (it was in several pieces), I noticed a few hornets around the door frame to the right. I had been turning to the left to get the pieces. I took a look and yikes, a soccer ball size nest was on the door frame and wall to the right, right at eye level. Don't know how I didn't see it initially, was probably going in looking down to make sure I didn't trip on anything lying on the floor :lol: I was maybe 6" to a foot away from it where I entered the shed each trip. As I stood there, more and more hornets were coming out or arriving. I got some spray and stood back and let them have it. Well, a bunch came right at me. One hit me in the forehead, another hit my glasses, one on the side of my head. I blasted a few right out of the sky. All of them kind of bounced off and I figured that was enough and just walked away before another attack as I was out of ammo (spray). Don't know if it was the tons of Deet I spray on before I work in the fields or luck but I didn't get a single sting. In fact, in 10 years of working on that property I've only got stung once on the back of the leg. Dang hornet then followed me to my truck and kept trying to get me as I swatted my hat at it. Got the spray and nailed it. Not a swarm, just a single suicide bomber hornet.
I kind of shrug when I hear stories of guys getting stung numerous times but figure my day is coming when I'll run over a big one or step on one and be running for my life. :shock:
