perfect easy out.
UncleTom
Again I had to drill something out. This time it was a main jet in a small engine carburetor. I use a torx bit of appropriate size. Drove it in and it comes right out.this was o ly brass but have used it on steel. It is amazing.
I pounded a 12 mm onto a rounded off 1/2'' hex. I was proud myself until the side of the wrench cracked. Oh Well, a little welding and the wrench will be usable again.
(quoted from post at 19:19:27 09/06/22) I pounded a 12 mm onto a rounded off 1/2'' hex. I was proud myself until the side of the wrench cracked. Oh Well, a little welding and the wrench will be usable again.
Situations like that is where this Metrinch set comes in real handy. The sockets and wrenches work on the flats of a nut instead of the sharp corners. Even with bad rounded nuts, you'll always find a size that will work on it. There is no such thing as metric or SAE when using this set.
