Bernard W.
Have a Perkins AD3 152 in a 135 Massey that misses when idling. Seems to be worse after engine runs for a few minutes. Replaced injectors and injection pump which made no difference. Valve lash is correct and timing gears are not worn or sloppy. Adjusting timing on pump does not stop miss. Compression is good and when accelerating or under load it runs like a top.
What else could be wrong? Could a weak lift pump cause this?
Thanks for any advice or suggestions.
