I have read many discussions about cleaning the inside of gas tank with phosphoric acid but no mention of outside. The inside of my 530 tank is clean but there is surface rust on about 50% of the exterior. This is the result of 49 years of West Tennessee climate on a tractor always kept under a shed.
I have used Jasco Prep & Primer (aka phosphoric acid) on rust and it worked quite well converting rust prior to painting. I am considering using this on my gas tank exterior and sealing with synthetic enamel to prevent future problems. I"m not concerned with appearance since the tank will be completely hidden.
Before I try this I would like to know if this might cause any problems.
Can someone who has tried this or understands the chemical process tell me if this is a good or bad idea?
Any advice will be appreciated.
Gary
Gary
