pictures from friday
billonthefarm
Location
Farmington IL
A interesting day. It is wet from rain on wednesday but we are able to run. Had to get out bigger tractors to pull wagons.
We were getting along untill...
Its a long story but we ended up having to hook the second tractor on in front of the one with the duals to get the back wagon out. It started to come out backwards and then 8920 spun all four tires and stopped. Hooked on to the 8920 with the 7120 up on solid ground and got it out. Must be a broken tile or something here.
Travis and Nick hooked the wagons back together and Travis headed for the bins. A couple minutes later my phone rings. Travis says the hitch broke on the front wagon going down the road. Somehow he got them stopped in the road without a scratch on anything. Everything and everybody is safe. We had the road tied up for awhile but we were very lucky. Told Travis I would have needed new britches!
The guy who farms my dads palce had that same thing happen last year. It was a DMI 300bu wagon, he was not as lucky, he was turning into the elevator, it came loose ended up in an old store building, turned wagon over, was a mess. He quit pulling wagons this year, bought a semi, said it has saved him a lot of time and don't have to worry about old wagon hitches. His wagon was about 15 years old.
Jim
That weld looks like it caused the tang to shear as it acted like a chisel ,we have had tounges break that way as well.And JT get the cheap F350 going yet ??
That must be a harder steel because it looks brittle. I had a heavy duty insert to hold the 2 5/16 ball for my trailer break like that. I think it just got a good jolt and snapped clean off. The weld probably didn't contribute that much. It looks like a pretty good weld without undercut. Dave
If you look close you can see rust behind the back edge fron the beads on top thats where the problen started .
