Pilot bearing/bushing seized ????
Crazy Horse
We're working on a Massey Harris 101 Junior and it appears as if the clutch shaft is seized in the flywheel's pilot bushing or if it has a bearing, then the bearing itself is seized or frozen to the shaft. I'm not sure if the MH lines used bearings or bushing, but whatever they used the tractor is pretty much impossible to get into gear when running (lots of grinding) and it is NOT the clutch itself that is sticking.
Is there any way of lubricating that or freeing it up? I was thinking that if I removed the starter and jammed the flywheel ring gear teeth to keep it from turning, then the driveshaft that comes out the rear of the clutch housing could perhaps be turned with a pipe wrench and the shaft would free itself up.
Just a thought, I'm not a mechanic by any stretch of the imagination. Any comments or suggestions?
(quoted from post at 13:09:00 06/08/22) We're working on a Massey Harris 101 Junior and it appears as if the clutch shaft is seized in the flywheel's pilot bushing or if it has a bearing, then the bearing itself is seized or frozen to the shaft. I'm not sure if the MH lines used bearings or bushing, but whatever they used the tractor is pretty much impossible to get into gear when running (lots of grinding) and it is NOT the clutch itself that is sticking.
ow can you determine that it is not the clutch/flywheel/pressure plate? Tried starting it in gear?
It's likely you will tear up the machined hole in the end of the crank if you try to force it to turn. Try taking the coupler chain off the driveshaft, remove the bolts holding the carrier bearing at the back of the bellhousing, and IF there is enough clearance between the coupler sprockets, pry the driveshaft straight back a bit, to see if it will come out of the pilot bushing or it will pull the bushing out of the crank. Mine was so boogered up I had to machine a new bronze bushing that would fit the chewed up hole in the crank. You might have to loosen the bellhousing and jack it up to get the clearance between the sprockets. If you have to do that, loosen the front engine mount bolt too, to allow tilting the engine up in the back. If, when you take the chain off the driveshaft, the sprockets are not aligned, that's part of your problem. You will have to shim the front engine mount bolt up or down to align the shafts. steve
Good question JMOR. If for example I put the tractor in any gear and keep my foot depressing the clutch and then start the tractor, it starts fine and the tractor doesn't lurch forward at all, just like one would expect. When I then release the clutch pedal, it grabs about half way out and away I go in whatever gear I was in. From that I assume the clutch is working, does that sound right?
Thanks Steve .... so the last part of your reply is suggesting that for whatever reason, the shafts on either side of the coupling sprockets might be out of alignment so the clutch shaft in turn might be slightly out of alignment with the pilot bearing. Since it is in place, it then would sort of be jammed into the flywheel bushing and act as if it were seized. Am I interpreting the last part of your reply correctly?
If the input shaft is seized on the pilot bushing you would know it from the squealing noise.
If it has a bearing it could be seized to the inner part of the bearing.
But Im betting the input shaft splines or seized on the clutch disk. Does the bell housing have a access plate you might be able to get to the pressure plate bolts.
That's exactly right. Mine had come loose at the front of the motor, dropping the front down maybe a quarter inch. That pivoted on the bellhousing mounts on the side of the frame, pushing the rear end of the shaft at the transmission way up. It ended up destroying the pilot bushing, and the clutch shaft splines. It could put a LOT of pressure on that shaft, all the way back to the chain coupler. You'll be able to tell by pulling the chain apart and off. The sprockets should line up within maybe a 32nd of an inch. steve
and with that much force against the front end of the clutch shaft, the friction at the pilot bushing alone will be trying to turn the shaft, even with the clutch fully disengaged. At a minimum, you are likely to need a new pilot bushing. The clutch shaft is pretty hard, so if you are lucky, it's still smooth and shiny. And you'll need to tighten up the front engine mount, and shim it to align the coupler sprockets. Also, check for cracks at the bellhousing mounts. They are not designed to flex. Pulling the clutch shaft, and getting into the pilot bushing that's pressed into the crankshaft can be a hassle. Let me know if you need more info. steve
Actually, at least one of those cast bell housing mounts you mention is at least cracked and maybe part of the mounting casting itself broken off near that pin that is anchored into the tub ..... I'm not near the tractor right now. But That is common with those tractors, I've seen several like that so didn't give it too much thought with regards to this current problem. Funny thing is that I used the tractor last fall to pull our pulling sled around our club's site for winter storage. We had just had the tractor given to us and I don't remember that issue at all with the shifting problem and getting the tractor into gear like it is now.
Hello John. No squealing noise. When I'm with the tractor next time, I will look for an access plate to get to the pressure plate bolts. If it has one, what are you suggesting?
Hopefully its a recent thing, and can be fixed by realigning the clutch shaft. There's a heavy metal plate bolted to the front of the frame, under the radiator, and a single large bolt holds the front of the engine onto that plate. On mine the two plate bolts were loose, allowing the plate to sag under the weight of the engine. I replaced them with grade 5 bolts and lock nuts, then I shimmed between that plate and the engine, to adjust the rear sprocket alignment. Hopefully that's all you have to do to fix the drag on the clutch shaft. Yours may be a bit different at the front, because my plate looked 'farmered' to me. steve
I suspect that might be the next step .... well, move the engine forward I guess it would be in this case. Thanks for the feedback.
I will check that out Stevie. Meanwhile I forgot to mention that if I engage the PTO/Belt Pulley system, the shifting into gear from neutral while running seems to be easier with somewhat less grinding. Interesting problem. I'll be able to check things out in the next few days when out at our site. Thanks ...
(quoted from post at 13:08:11 06/08/22) Good question JMOR. If for example I put the tractor in any gear and keep my foot depressing the clutch and then start the tractor, it starts fine and the tractor doesn't lurch forward at all, just like one would expect. When I then release the clutch pedal, it grabs about half way out and away I go in whatever gear I was in. From that I assume the clutch is working, does that sound right?
If the input shaft were seized to the flywheel, the tractor would take off instantly when you hit the starter, regardless of the status of the clutch pedal.
You would not be able to start the tractor and initiate movement by letting out the clutch.
It might be hanging up but it's not seized.
B-E ...... yes, I can see your point now that I think about it. What might you mean by 'hanging up' (as opposed to seized)?
As I mentioned later to one other guy who replied, when I engage the PTO/Belt Pulley, the problem seems to be reduced somewhat ..... still grinding when attempting to put in gear but less of an issue.
Anyways, back to the meaning of 'hanging up' ???
Clutch disc could be warped,or clutch disc is sticking to the flywheel but releasing on the pressure plate side.Or the splines on the clutch shaft are a little rusty and not letting the clutch plate back off or the clutch shaft has worn a groove holding the clutch disc against the flywheel.
The PTO engaged may be enough drag on a spinning clutch shaft to counteract the friction at the pilot bushing, and makes sense that it would partially relieve the problem, IF the problem is as we've been discussing. I'll wait for your reply once you take a look at the shaft alignment. steve
