I agree, there is zero need. I would use a different hose on the intake to the little pump. JimI never reuse brake fluid that I vacuum out when bleeding the brakes". It is just not that expensive to always refill the reservoir with new. IMHO. but thanks, I do clean it with brake clean and air.
Understand you got the plug out, but to assuage your concerns about fire for future projects...I have a drain pug on a Farmall H that drains the transmission. The previous owner/owners have this pipe plug all rounded off and knarled up. I tried squaring it up a bit with a die grinder to no avail. It sits in a very inaccesable space, can't get a good hold on it with any thing. Normally I would put the heat to something stuck, but with a couple gallons of gear oi right behind it I'm a bit concerned about a fire. Any help or suggestions would be appreciated.........gobble
If it has the plugs with the recessed ⅜ or ½ square that a rachet fits in, get a set of pipe plug sockets.Not the same as your issue for a plug. On my 856 The drain plugs were so tight I could not get them out till I put a jack under the ratchet and put pressure on them so the square would not slip out then could get them to unscrew Once out replaced plugs with new ones and dind't tighten like it was the end of life it it was not that tight again. Just drill it out so the rest of the oil drains then heat the plug and let cool. The oil will seep into the threads and probably come out or just drill it out till almost gone and it will probably unscrew with a left handed drill.
