Pipe size for boom pole
I need a boom pole all the time and none to be had in SE AZ. No one sells em around here. Sooo, just like most of the stuff I need I guess I'll build one of those too. Question, what size pipe is used to make boom poles?
Use square tubing. It is easier to work with and is stronger too. Here is a picture to look at. I have made several and I used 3 inch tubing with 3/16 wall.
How much do You want to lift? Do a search for...
everythingattachments.com
They sell many different sizes, & weight limits, & give most of the sizes of the framework; but dont tell how thick the steel is. They can ship one to You. A light weight, about 2" pipe. Get into a 2000lbs lift unit, & about 3" square tube. The real stress placed on the boom is when the item being lifted sways a lot.
The one I built I use 2 or 3 inch pipe then topped it off with angle iron so as to make it heavy duty. I have since made it so it also fits my loader bucket so I can get extra high lift for when I need to lift up beams for a building I might want to build
Doesn't HAVE to be made from pipe.....
<a href="http://s261.photobucket.com/albums/ii44/thurlow8/?action=view&amp;current=firewood00121.jpg" target="_blank">
firewood00121.jpg" border="0" alt="Photobucket
</a>
<a href="http://s261.photobucket.com/albums/ii44/thurlow8/?action=view&amp;current=firewood003.jpg" target="_blank">
firewood003.jpg" border="0" alt="Photobucket
</a>
What size tractor? That will be a decideing factor, a cat 2 hitch will lift heavier than a cat 1 hitch and then even on a cat 1 thehitch on a 60 HP tractor will lift way more than on a 20 HP tractor. For example a Ford 9N against a Ford 5000 and cat 1 will work on both tractors.
Richard, found this interesting one in Abilene's CL.
http://abilene.craigslist.org/grd/2967494075.html
Since its on a dolly, might be worth the drive???
Also have a friend here in SW OK that was thinking about selling his boom/winch truck. I know he's reasonable. Email is open if you want me to check on it....Ralph in OK.
