Piston Ring Not Marked Or Beveled?
I Ordered a sleeve and piston kit from this site but could not find a pip or bevel on top ring. Can I assume it makes no difference how this particular ring is installed ? Other rings I have installed we marked . I received 4 wrist pin circlips but I will assume that was just in case one or two went flying . Thanks.
Bill M. From Illinois , If there is no pip mark or taper on the top ring and is a perfect rectangle looking at the end.The ring can be installed either way.Also check the piston top compared to the other piston tops.(one could be domed and others flat top) Notch to the front and install the rod with the niches in the same direction.
