pistons for c-301
Napa can get the stock firecrater up to .060 over. A higher compression piston would be a flat top piston. Check out Ross Pistons they have them from std bore up to bigger bore sizes. Maybe a truck engine piston would do fine,,,,, Most of em were flat tops.
I will be glad to get you a price in a few days. I am a little busy farming right now.
If you like I will call you.
(quoted from post at 16:24:59 10/22/07) if you want to give me a call the # 901-828-6589 I still need a set of pistons for a 301
New ones are expencive!! Hint,,,, The C-200 gas 4 cyl Ih engine, uses the same piston as the 301. Same overbore options, dont know if high compression options are available or not. Anyways,, might buy 2 kits of the C-200 kits, have 8 pistons and maybe,, up to 100 bucks cheaper, and have 2 extras.
(quoted from post at 00:25:40 10/18/07) I have a set of 301 +.040 Hi Alitude I-H pistons for sale (used)
Hello, I know this is an old add, but do you still have these pistons for sale? thanks
