pitman shaft seal mf 204
94yj
I have a massey ferguson 204 workbull. and The left steering shaft "one the pitman arm hooks to" is leaking some fluid how hard is it to replace the seal
You mean up by the steering box right? Those seals are easy to replace but you have to adjust the sector gears (also called pitman shafts I believe) properly afterwards using the manual.
this is the seal that i am trying to replace and was told the 35 and 135 and other took the same gear box sorry for the pic size
I can't really tell from the picture. Probably best to go to the acgopartsbooks website and look up a diagram from there. Often the parts numbers can be googled or cross referenced from there.
Yes, the 35 for sure used the same gear box, not sure about the 135, maybe. Any of the workbulls, 202, 203 and 205 will all work.
