Pittsburg cultivator guide disk
Ive got an old Pittsburg cultivator. Salvaged the guide wheel, hub, and braces off another unit.
Ill never get around using them. Can send pics later. Might work out a deal if shippings not too bad.
I'll send a pic of what I've got this afternoon. They're yours for the price of shipping.
I have the wheel, hubs, both adjustable brackets, and the support bars. Probably missing some nuts, bolts, and spacers. Not sure the condition of the bearings.
My email is open on this site.
I need to locate a replacement disk for my cultivator. The sweeps are easy but disk is hard to find.
If the disc bearing is good just weld a new old disc the same or similar size to the front of it. Cut out a hole big enough so you don't get the bearing hot and cool with oil after welding to keep the temper in it.
If ebthomas only needs the hub, I can separate them.
Id prefer all of it to go together, but Id be happy if anyone can use them. Lord knows Im not.
The disc is straight with some chipping/rust on one side. It probably measure 15 1/2 in center line.
I'm definitely missing some spacers.
The hub rivets looks like they will take considerable effort to separate from the disc.
There is no bearing. Either it ran in a bushing or took grease; there is a weep hole in one hub. I planned on installing a zerk...a decade ago. A 1/2 in bolt/axle fits pretty good.
Separating that old hub might not turn out
well. Billion cultivators used a
stabilizer disk also. I've been looking
for one of those disks as a possible
replacement.
