Hey guys. I am in the planning stages of preping/painting my '39 Deere B. Here are my goals for the tractor. I would like to make it look respectable (but dont plan on showing it). It will probably be kept indoor when not being used. It will not be used as a work tractor per say, but I would like to get a plow eventually and maybe do some heavy garden work. THat being said, what do you guys think of this plan of attack...
1-take most of removable parts off, engine will stay on, radiator on, but remove seat, sheet metal, carb....and then first clean everything off.
2- was told i should rent a sand blaster. rental place near me has a 100 lb pressurized unit I can get for 50 bucks/day (one day needed????). will do blasing outside and this will probably be the only time i use one, but think i will stay away from sand nonetheless. aluminum oxide? glass? charcoal stuff?
3- looking to get a spray gun. lookin at the high end TSC guns (oxy moron?). what do you think? http://www.external_link/webapp/wcs..._____14151|14152|14168|35500?listingPage=true
4- will shy away from TSC paint, but figure if prep work is done correctly, Deere paint/primer will work? i have heard it isnt that bad, both quality and price. i havent checked numbers, but how much price diff is there with the PPG Omni stuff? Was also suggested to use etching primer, will that be needed if i use the blaster?
5- put stuff back together, finish paint the bolts/scratches that i will most likely make when reassembling
sorry this is so long. but, what do you guys think, any suggestions? once agian, not gonna be a show tractor, but would like to make it look nice....like makeup on an old woman
