ChampagneNBeer
Hola,
Getting to fall planting time & need your help. 😀
Looking at busting up roughly 10+ acres this fall to get use to running the equipment.
Planting some multi-acre sections on wheat, oats, clover, peas etc (not mixed, all seperate, except one mixed area for a deer plot)
As depths range from 1.5" to .5"/surface I know the John Deere 8250 can knock it out but at 14 feet, it is too big a planter for the small acerage per crop I am targeting this fall.
With that in mind - what planter do you recommend (vintage/inexpensive/easy to learn, use, fix etc)?
Goal:
A planter than can run rows, broadcast, run depths to say 3" and be used on seed sizes grom grasses to possibly even corn?
Also, needs to be mid-sized unit that is best for smaller sections but not so small that anything over 1 acre is alot of back and forth.
Thanks!
Goal:
Thanks!
