play in hub
Regarding a John Deere model B narrow front end: I'm ready to replace the steering spindle and roll-o-matic with a used spindle and roll-o-matic. Upon inspection of the replacement part, with hubs only, no wheels, one of the hubs moves in and out roughly 1/4, the other doesn't appear to move in and out. Before the hub is taken apart for inspection, I would like to know a possible issue for this in and out movement. I will be transferring the wheels/tires over to the replacement part once the replacement is installed. Thoughts please. Thank you in advance.
The issue would be a bad bearing and race.....I would take both hubs off now.. Check the bearings, races and felt seals.. Are spindles good?? Replace items if need; pack with synth grease, Assemble- tighten, pin..
