[email protected]
Ok here it goes. I am trying to get a ford 8N side mount tractor running for the last month or so. The tractor was my wife's grandfathers that was in my father in laws possession and sat for 10 years. I wanted to get this tractor running so I followed similar forums and got it to run like a top. I had it for a year and it built a driveway, cleared snow, moved a ton of dirt, etc. Well once the father in law knew it ran so well, he came and got it back from me
Moving forward, he had it again for 10 years and didn't move, wasn't even sitting in a level place the entire time. One day I come home from work and it is once again sitting in my driveway. Called him and it doesn't run and he doesn't want it anymore. It had 4 flat tires, rusty, generally in bad looking shape.
First of all, got tires all back in shape so I could at least roll it around. Then started from scratch. I changed oil, oil filter, cleaned air filter, put oil in spark plug holes and let it sit for a few days. Then hooked a battery to it and nothing. Had to take starter apart and clean and put back together. Violia, turned over but no spark. 12V Coil had a small crack in it but was still functional. Changed it out anyways with an internal resisted 12V coil. Changed battery, points, condenser, spark plugs and wires. Now I have excellent spark at plugs, nice and blue, jumps 3/16 easily but no fuel. Took apart tank valve assembly, cleaned it and both screens really well. Now bam, starts right up but wont stay running and when it does, it back fires like crazy and had limited power. I then fully rebuilt carb and made sure ports were cleaned out really well. Try again, no change until I completely burnt out solenoid. I then replaced solenoid but had no spark again so I changed out several wires and solders new ends on several others. Spark again, lots of fuel when I pull carb drain plug. but will only fire for 15 seconds and quits, choke helps a bit but still dies off anyways. I have spark and fuel immediately after it runs. Plugs however seem dry when I pulled them so....... compression test.
Cyd#1 - 90 dry, 100 wet
Cyd#2 - 70 dry, 85 wet
Cyd#3 - 90 dry, 105 wet
Cyd#4 - 85 dry, 100 wet
I then brought #1 cylinder to TDC and could see the timing mark so I checked the distributer and its pointing at cylinder #1. I once again opened carb and cleaned every passage...... No go.
I am at a loss, I've put so much time and money into this thing already and cant even move it around yet. Can someone please pitch me a few ideas.
