Please help ID this little fellow
profire31
Just trying to figure out exactly what this is. I"m more familiar with the N"s and not a Case at all. Are parts pretty easy to get? Thanks so much for all your help.
Cliff
What you have there is a VAI. That is the Industrial version of the VA series tractor. There are a few differences between that and a VAC. However engine parts are the same and fairly easy to come by. Things like side panels can be found on ebay regularly.
VAI. Should be later model with that style front axle and torque tube. Earlier ones had a straight axle made from bar stock as opposed to cast as this one has.
