This is a friend of mine's tractor. He said it stopped cranking. He put a new starter in it. Still nothing when pushing factory the button in front of the shifter but cranks if you jump from the battery to the starter. I offered to help. I tried jumping across the solenoid terminals and not even a spark. Measured battery voltage... battery was dead. It's a brand new battery. Put a good modern charger on it. Then I was getting spark and a slight turn of the starter.
I decided to buy a new solenoid (factory style) and a new positive battery cable as it looked bad. Waiting on those parts. Will the original style solenoid handle 12v?
He also had a GM alternator on it which he said turns too slow due to the pulley ratios. Not sure what can be done with that.
What year do you think this is?......
