Please identify my Case plow
dfarmann
Did they ever stamp Model and Serial numbers on these plows? I can't find them if they did. If someone would be kind enough to id this plow I am going to write it on the main frame beam. It's a 4-14" if it matters. Thanks.
I hope.
I do not see the "railroad" iron beams to be a model "A" also the hitch only pulls from two points on a GR/GT plow like I am sure I see in your pic,a model "A" and "CH/CHT" plows pull from each bottom at the hitch, look at the tail wheel lift at the front axle point,, only a GR/GT plow has this type as seen in these lit pics if yours is a shear bolt plow its a "GR" if it has trip style bottoms (a adjusting screw is on the top of the beams) it is a "GT"
cnt
shear bolt style beams are a CR if it has trip type beams a CT, this pic shows the trip beam style, see the adjusting bolt at the top of each plow beam? if yours has this its a GT, if it does not have the square headed adjusting bolt it is a GR
cnt
Those quick couplers are not going to work like you have them. The female ends need to be mounted SOLID so the male portion can pull out when the plow unhooks.
Loren
Im thinking its a: Hose extention / Deere tip to Pioneer tip combo assembly. Been there do that.....I think I got the same plow too. Need to go take a pic.
