So here my story. I bought a Ford 1200 tractor with 830 hours on it that had been sitting for a year. I bought it not running. Put a starter on it, bleed fuel system, added hydralic fluid and she ran like a dream. After puttino two or three hours on it I'm driving across our field and it starts to die, like a idiot I didn't immediately turn it off. It died an I opened the hood to check the gas and I had coolant overflowing out of my radiator cap. Radiator cap was still o but coolant coming out the sides, as,if it over heated, it was full of coolant. But when I checked the gas tank, it was bone dry....I bleed the fuel system gave it a shot of ether and it acts like it's not getting enough cranking amps but it makes a sort of griping noise when I crank it over. It will crank once,or twice then stop on a grinding noise. Won't start. Need help. Thanks also, usually if it runs out of gas I have to bleed the fuel system, when I bleed it st first no gas,came out for a long time. Not sure if that,means anything or not.it's a,2 cylinder diesel and yes it had oil
