Plow bolts, autch!
4xMF
Location
Denmark
Changed some plow shares and landsides today. Cut my fingers on the worn bolt heads as always of course. They are as sharp as razor blades.
I have some of those wounds also. Now days, I torch off the nuts and bolts. Much quicker and easier. Now how
do I repair the hole on my shoe from stepping on a red hot remains of a nut??? HeHe
Loren
years ago, we were changing cutting edge, co-worker was using impact when bolt
began to spin. without thinking, he reached around to hold it-----
ACG I have stepped on a few red hot plow nuts too. My soles are thick so I usually hear a sizzling sound before I feel anything! A year or two ago I was torching a nut off of a part for one of the plows and a lucky molten ember made it down on the tongue of my boot. I didnt notice it at first thinking that the leather boots would repel the small bits coming off the plow. Well the tongue is made of nylon... It started as a slight sting and grew very quickly in intensity. I looked down and smoke/fire was rising from my boot. I almost threw the still burning torch and began ripping at my boot to get it off!
If I?m in the field I use a hacksaw to cut the one flat
off the nut then use a chisel to break the nut off then
drive bolt through sometimes I use the die grinder
On the chisel plow I use a portaband saw. Another trick is I hard surface a ring around bolt head area so it does not get as much wear and most of the time the bolt come right out.
I?d like a portaband some day . I bought some hacksaw blades from John Deere that cost about 12$ each I?ve cut hardened steel with them and they make short work or plow bolts I?d almost rather hacksaw than use the die grinder .
I have that familiar horseshoe shaped scar on my left pointer finger too. We only do it once. Now I press on the bolt head with a pliers. It usually works.
