Plow identification and parts help
I am hoping to get some help identifying a 2 bottom plow that I recently purchased and help locating shares if they can still be found. Unfortunately the manufacturer's plate is missing. The Moldboards are stamped with AO110 and the shares that are on it are stamped 14A AO-120 A. I'll post a pic. From the research I have done this is some sort of Ferguson plow? Any help is greatly appreciated.
(quoted from post at 08:00:01 04/27/23) Standard Ferguson 2-14 inch plow. Could be in range of 1939 to about 1957.
Thanks Leroy! This confirms what I was thinking about make. Now the trick is to find any shares that will fit it. I have not seen many with the three bolt pattern.
12 inch 2 bolt, 14 inch 3 bolt. If they made a 2 bottom 16 inch I have never
seen one and for single bottom I know they made them but also never seen one
so don't know if it might have been a 4 bolt. Longer share needs more
holding power. A lot of plows used a eye bolt under the share for tightening
but the Ferguson 12 inch did not do that. I still have the ferguson but has
Ford name cast in beam that Dad bought new in May of 44. I think that plow
could be one of first with smooth sides to beams. Other makes that I am not
that familar with also used flat sided beams.
