plow measurement
Center line between beams is good on most older plows but not all as some are adjustable with vertical bottom supports being offset andreverced front to rear bottom to change size. We need to know make and model to know how to do it on your particular plow. John Deere is one of these plows that you do not measure that way.
You measure at 90 degrees to the share or crosswise, in order to get the width of furrow that it will turn.
