Plow question
plowman540
what does it mean when a plow is a steerable plow? the plow i have is i believe a 540 international semi mount steerable plow and what are they worth also?
There is a steer arm that runs from the hitch to the tail wheel. Thus it is a steerable plow,not a fullmounted plow with a stationary rear wheel.
Saw one sell today at a auction for $125.
Gary
I had a 540. Nice plow. Pulled it with 1st a 706 then a 4230 J.D. Clip on 3 pt. came out once and I tipped it over going around the end. Right on state hyway 14 during rush hour, mile and a half from town so 10,000 people could see me. Sorry I don't know what they mean by steerable as every semi-mount has a steerable tail wheel so you would not think they have to point that out. That would be like pointing out that a pull type plow has a hitch.
do youn have to hook anything to that arm or do you just hook up only to the two 3 pt. lift arms and the hoses to the cylonder
Your 540 has the steer arm. No you do not hook anything up except the 3 pt and the hoses.
Gary
The stearable would have a piviot at the hitch so the tractor could start to turn before a d that arm would guide the rear wheel in relation as to the amount of turn in that front piviot. Now some early semi mount plows did not have that pivion at the front and that was rigid in keeping the plow alighned behind the tractor like a fully mounted plow and the only thing the tail wheel did was carry the weight ov the back end of the plow that the tractor was not capible of lifting or lifting and keeping the front end on the ground. was probly gust like a caster wheel. Early Ford plows were like that and I think the early 4 bottom for the AC WD45 was also like that.
Around 'here', they're worth not much more than scrap prices; got a 5-bottom, a 6-bottom (both F145H JD) and a couple of 5-bottom mounted rusting away in the fence row; should sell 'em, but hate to see them go for scrap.
