a,rothermel
what size plow would you recomment behind an oliver 1655? the previous owner pulled 4 16's. I am thinking 3 16's. The ground that we plow is really tough. What do you guys think?
I have a set of 4 x 14" behind my 1650D with 18.4x34 loaded tires. As long as the ground isn't muddy it pulls fine in 3rd direct. That being said, in real hard ground the same plows would give the 1855 that I used to have a real work out. Stu.
I pull a 4-14" Oliver 5540 with my 1655 diesel and like the match. I will change plow to a 4-16" when I get a book on plow. Tractor has 18.4x34 tires with 3 weights each side and has a front loader. I have pulled it in sod (old hay ground) 8" deep and it did fine in 3rd gear.
I got a super nice, low acre 508 White plow that would be perfect for you! Those 508's are a pretty darn good plow.
We live on clay ground. Our 1650 diesel pulled 4x16" Oliver plow good in any conditions except on hills where we had to drop back on the 2 speed. As kids, we always dreamed like we were at a tractor pull so we ran it deep too. This tractor was a dealer demo unit so it might have been turned up a little. But it did not smoke much either.
In our soil up here in NE Wisconsin, it's 20-25 HP per bottom, no exceptions. I pull a 4x16 with our 1855 that puts out a strong 105 HP, and I'll have to pull in 2nd gear sometimes. MOst of the time it's 3rd direct.
I put our 1600 on the 3-16 plow for the 1st time in a good 25 years. Was surprised how well it pulled it, but it has an overbore kit installed to bring it up to 1650/1655 specs. I could go 3rd direct in all soils I found with it, and I was even able to go into 4th gear in some really mello soil.
I'm gonna go out on a limb and say your soil just isn't as hard as ours and you should be able to pull 4-16's. Unless you're in this corner of Wisconsin as well.
Donovan from Wisconsin
I pull a 4 14 oliver and 4 14 Jd plow with my 1755 and it just plays with them. Not at the same time of course:>) but I would imagine that 4 14's may be a good match for the 1655 but 14 inch plows are mostly worn out and hard to find parts for in my neck of the woods. A good 3 16 should be easy to find and won't bother your tractor at all. I also try to follow the 20 hp per 16 inch bottom rule seems to work good.
