plowing question
I'm plowing with a Ford 151 4x18 semi-mount plow and I can't seem to get it to leave the dead furrow clean. So on my next round its rough. It seems to be plowing decent to me except its not cleaning the last furrow. What am I doing wrong?
Try moving the rear coulter farther out, towards the furrow wall. Then if that does it, move the other's over as well. In our plow manual for our 4 bottom IH it says to do that on the rear coulter and once set do it on the rest. And in sod that you might have to do this. Corn ground not as big of a deal.
Does the plow have disc colters?
They should be set so they slice one to two inches more than the plow bottom.
My colters are also set about 3 to 4 inches deep.
Without colters I don't ever see a furrow cutting clean
Gary
Ok thanx guys. It does have coulters and I've been playing with the back one but I was trying to set it close to the point. Ill move it out and see how it works
Can't sya on his 1086, but on our Oliver 1855 we've got somewhere around 800 lbs on it. It just keeps the front end planted on the ground. If you're riding a bucking bronc, then you could use more weight up front.
Donovan from Wisconsin
That's what I figured. I went from a Deere to this
IH and it just doesn't ride as smooth. I've got 5
weights on the front but I guess ill have to hunt
some more down
Full set (10) but I"m pulling 6-16"s. Some of the bucking around may be from wheel slip. How is your rear weighted?
Air ride seat helps a lot.
Gary
I gotta say the impression I get from driving around a 986 that we rent on occasion, is they're pretty light on the front end without weights. Atleast it seems lighter than our 1855 did before we added the starter weight, 1 stack and 4 slabs to it. The only time it rears up is when I snag a tree root close to the fence row.
Set the coulters so that they're leading in the cut that the shin wants so make... Then it should cut clean and reduce shin wear.
Rod
