Plowing with a 4440
Le9102011
Hey all gots a question. We are having a plow day and surprise surprise I have never plowed ground in my life. Ive got a 4440 with duals and a John Deere 9850 4 bottom roll over plow. Tested it out a little bit today and my question is should I pull the duals off so I can put both the front and rear tire in the furrow or just leave them on and let er rip.
You might want to just plow in the same direction as the other plows. That way you only need to remove the right hand dual.
There could be problems for the people plowing behind you if you roll your plow over at the end of the field and head back down the same furrow you just came out of.
