Afternoon everyone. I recently bought a live pump from a super H for my 52' H. My H should have the correct cam gears and front cover holes. I want to use two way cylinders for my loader so I have a few plumbing questions as I've see a lot of different options.
I want to run the supply/suction line from the drain plug of my gutted lift all reservoir to the input on the new live pump, then run the output line to an open center valve with a built in relief valve, with a spin on filter in between, not sure if this is the best place to run the filter or not. Then run the return line from the spool to one of the old output lines from the lift all system. It seems some guys use the fill neck or Tee to the drain along with the suction line for the return line but i think the old output makes more sense unless I'm missing something. And lastly if i use the old output for the return do i need a sealed fill cap or can i leave it vented. Thanks!
