Ted in NE-OH
If you were replacing the plumbing in an old building in a cold climate what would you use plastic, copper, pex or whatever.
Will Pex stand being froze once?
(quoted from post at 01:08:57 01/05/18) With pex pipe, "sharkbite" fittings are usually involved. I needed a sharkbite fitting in an area subjected to freezing. I even called the company, and couldn't get a straight answer on yea or nay. So far,so good.
(quoted from post at 14:25:24 01/04/18) If you were replacing the plumbing in an old building in a cold climate what would you use plastic, copper, pex or whatever.
(quoted from post at 17:02:16 01/06/18) Pipe insulation will not stop a pipe from freezing unless there is some source of heat such as tracing. Copper by the way is my choice of
material.
