lastcowboy32
ballast resistor
if you trace your wiring... the coil DC + should go back to one terminal of that... the other side should connect to the key.
check out this old thread...
https://forums.yesterdaystractors.com/viewtopic.php?p=9702003&sid=84746d369241f38b9026e97843885408
if your points are stuck closed... hot ballast resistor
if you have a short circuit in the wire from the ballast resistor to the coil DC+... hot ballast resistor
if the ballast resistor itself has a short to chassis somehow... hot ballast resistor
That resistor should only be hot when the engine has been running for a little while.
