kendak
need some help please...working on a JD 720 LP tractor ...12V neg. ground...tried the Pertronix unit & when I pulled a plug wire the spark spike burned the new unit up...talked to pertronix & they tell me thats what happens if you pull a wire [suppose to ground it out not pull it off]..anyhow installed new points & cond. & tractor ran good for about 5 min. & quit ..the points had gotten so hot that they were blue & burned...I did install a new Blaster 2 coil at the same time as the Pertronix using ballast resistor that came with coil..I think now that the coil is the problem with both units ..can anyone enlighten me...thanks ..Kent
Heres the deal, an advantage of an elec switch is that it can switch n handle more current then points were designed for. Therefore with an elec switch one can pump more current through a high energy coil to get a higher energy spark. Soooooooooo if the new primary circuit (coil + ballast) has less ohms total resistance then say 3 ohms (stock full true 12 volt coil) and draws more then around 4 amps (near what a stock system may draw) there may be more current being switched then the points were designed for sooooooo they burn up faster.
Another cause of premature points burn up is no conednsor or a weak condensor or one mis sized.
You really need to know the resistance of that coil you have and the ballast ???????? If its total (coil + ballast) is around 3 ohms THEN THATS NOT THE PROBLEM BUT IT ITS FAR LESS THATS WHY THE POINGTS BURN UP QUICK or else the condensor is bad or mis wired.
Id try the old regular full true 12 volt coil or else a 6 volt coil plus ballast n see how the points last and insure the condensor is good n wired right also. CHECK RESISTANCE OF THAT PERTRONIX COIL AND BALLAST ALSO with that info I may be able to help more
Perhaps that coil was the cause after all???????? If you had a dead short versus the regular coil and ballast resistance
that may over current the elec switch !!!!!!!!!
John T
John T
Actually, the original Pertonix Ignitors don't do a very good job of "handling" a low resistance (high output) coil. If the ignition is left on with the engine stopped at a point where the Ignitor is constantly triggered it's NOT uncommon to "let the smoke out" of the Ignitor, as well as the coil.
Their website has information on what type of coils can be safely used.
The Pertonix II units, for those applications they are available for, are "smarter" and will keep the primary ignition current under control, protecting themselves, as well as the coil.
"Heres the deal, an advantage of an elec switch is that it can switch n handle more current then points were designed for. Therefore with an elec switch one can pump more current through a high energy coil to get a higher energy spark."
As I stated in the other post, NOT true with the Pertronix unit, UNLESS it's an "Ignitor II", and those are NOT available for all tractor applications... more of a "hotrod car" thing.
I actually burned up [2] Pet. units & in contact with Pet. one was MY fault because the MSD Blaster coil comes with a .8 ohm resistor & Pet. states that you have to have at least 3 ohm. total but I burned up one just pulling the plug wire off to set the carb. & that was their fault because it not stated in the instructions that you have to ground out the plug not pull the wire..I don't want anything else to do with electronic Ing. I'm just trying to get my points to work now...will purchase new points & coil from this website but they don't list the resistor...where do I find the correct one without going to mother Deere ??...by the way [2] Pet. & [2] Blaster coils set me back about $300...could have bought a lot of points for that many jingles...these were installed on a 720 & 730LP...you would think I would know better than mess with success since I been working on these 2 cyl. since the 60's....thanks for the help...Kent
I agree, some (NOT all of course) high energy ignition systems use an elec switch thats capable of handling n switching MORE AMPS then the 4 or so points can hande. Then if you (as I usually recommend) couple a higher current switch with a high energy coil and pump more amps through the coil YOU CAN GET A HIGHER ENERGY SPARK...
I think Pertronix or others make Flame Thrower and Flame Thrower II and Ignitor I and I etc so I always tell posters to be sure and match the coil n switch .......
Great and fun discussion, glad to hear your good comments
Take care now
John T
Somebody a while back told how to put a transistor in the circuit to greatly reduce the load on the points. I don't recall exactly when or whether or not it was on this board or one of the others. They also said what to use if it had a positive ground system instead of negative ground. I don't know if this is anything which might help you.
Are you running a resistor bypass to the distributor from the starter circuit or from the ignition circuit? It should be from the starter circuit.
It should be run from the starter circuit to bypass the resistor only when cranking the engine. If you run a resistor by pass from the ignition switch you will have 12 volts going to the coil & point at all times thus not even using the resistor.
Got the Eltronic Petrix ignition on the DC ,NO JOKE !,Most the time starts VERY EASILY . However , at the 1st sign of Weaknes in battery , The DC will not fireup at all /no spark , ,, Hook the HOT wire from battery cables to the coil and immeditely It is runnin , without so much as touching the starter button..strange but true
it is wired correct...only 12 when cranking...checks 7.5V when running...I can't understand how the points got this hot this quick...in 5 min. flat new points were blue & burnt a blister on my finger when I poped the cap...thanks for all the help but it's still not running...got [2] blaster coils for sale ....cheap....Kent
