(quoted from post at 19:57:03 06/26/14) JMOR, not to start an argument, but I believe the jumper wire should be touched to the armature terminal. It would be marked A or G. There should be a small spark and touch it once.
he small of success is 'wunnerful' isn't it? :wink:(quoted from post at 13:42:03 06/27/14) first, the gen light stayed on so not charging. Checked the Lucas gen and OK. replaced Lucas regulator and put jumper wire on the field on Gen and touched hot batt. side (not Ground side)with other end of jumper and held for about 10 sec. replaced wire to field on gen. Started tractor light went out and all seems OK. thanks for all replies. Pem
e" "a" ?(quoted from post at 16:50:19 06/27/14)The small of success :wink:
Sure beats the large of failure.![]()
