(quoted from post at 20:58:09 10/15/15) Osseo plastics. Osseo, WI.
(quoted from post at 21:41:24 10/15/15) Eldon a better floor than poly is fiberglass covered plywood. The poly flooring expands and contracts with temperature changes and usually cracks if it is in larger sheets. If you look at most new poly floored spreaders the flooring is in 6-8 inch wide "boards" that are 3/4 to an inch thick. The fiberglass covered plywood is what many Semi van trailer sides are made out of. You can usually find manufactures of the sheets around. You also can usually find wrecked trailers with good sections big enough for your needs. Also the boat repair business uses fiberglass covered plywood too. That might be a better route for you to look.
With the fibber glass covered plywood you can make the floor out of one big sheet. The wood in the center keeps the thermal changes minimal. The fiber glass outside gives you the wear and rot protection you need.
(quoted from post at 21:56:31 10/15/15) FWIW, used 3/4 pressure treated plywood on mine, it's held up 10-12 years now.
Fred
(quoted from post at 18:30:41 10/17/15) what do you haul that is above 500 deg?
(quoted from post at 15:30:41 10/17/15) what do you haul that is above 500 deg?
