Posi Traction Ford 4600SU
eagle24
Am I correct that you just stomp the pedal down to lock the rear end on a Ford 4600? How do you release it from being locked?
It will release itself when the uneven traction load is removed if you have removed your foot from the pedal.
That said, don't "stomp the pedal down" while the tire(s) is/are slipping.
Dean
When one tire is trying to slip it will apply an uneven torque of sorts on the diff lock holding it applied. When the torque is even due to equal traction on both sides it will pop back off. Or you could just hold it down and leave it locked as long as you want if that's what you wanted.
