New to the forum here, looking for some guidance.
I have been offered a Ford 6000 project, was an in use tractor a couple three years ago, owner passed away. Sat unused.
6400 hrs on the clock, turns over doesn't run, new battery decent seat.
Engine oil is black no AF in it, fuel system needs bleeding, I see some things in the fuel line that are possible air leaks.
When cranking can tell by sound there is one low compression cylinder.
Both fenders are straight, is missing a battery side cover and one screen air inlet radiator cover one side.
Will need a rewire (easy job for me I do electrical work)
Shows some evidence of some repairs over the years.
Needs rears, appear to be loaded with calcium, rims are rusting but no perforations or holes.
The big unknown is the trans or hydraulics.(that's the scary $$ part). Could not find a serial or trans hyd dipstick to see level or condition.
The current owner is asking $1500 cash firm and that includes the rollback to have it delivered to my shop.
Prior tractors I have owned are mostly utility size 35 hp and under an mix of Workmasters (New Hollands), H's, a WD45, several 9N, 8N, MF35, Cubs etc.
Nothing this big.
Presently have 2 8N's and a new Kioti CK2620 std trans not hydro with loader, with the usual 3 point toys, brush hog finish mower, back blade and a just acquired 11' JD KBA pull disc.
The 6000 would handle the disc nicely to level out my field of 4 acres that got rutted up. Either of the 8Ns will pull the disc as long as it doesn't bite in too deep, then I suspect I will run out of tractor. I don't really want to use the the new Kioti for the discing unless no other reasonable choice.
So, what to do?
Buy and fix?
Buy and part out?
Pass on it?
Thoughts?
Nothing this big.
So, what to do?
Buy and fix?
Buy and part out?
Pass on it?
Thoughts?
