(quoted from post at 10:35:51 06/20/18) What tractor? What are later and older style units? 9/2N pumps and lifts are different from 8N pumps and lifts.
I have a spare setup from a old tractor.. I want to keep tractor going while I rebuild pump and lift cover piston,rings, and cylinder.(quoted from post at 14:08:34 06/20/18) If you are trying to convert a 9n/2n to an 8n top cover and
pump than have at it. Later models won't work. In other words
an NAA top cover on an 8n won't give you live hydraulics
although it's not clear what exactly you are trying to achieve
ome on, give it up. What old tractor? Another 8N just like yours or older, or newer, or a IH Farmall??(quoted from post at 11:07:44 06/21/18)I have a spare setup from a old tractor.. I want to keep tractor going while I rebuild pump and lift cover piston,rings, and cylinder.(quoted from post at 14:08:34 06/20/18) If you are trying to convert a 9n/2n to an 8n top cover and
he double arm down to the pump says that it is 9N/2N & not an 8N. The 8N with single arm down to pump can be installed on the 9N/2N as long as the pump AND lift cover are used together, but you can not mix pump/lift covers. Also, if the hydraulic compartment of the tractor is 9N/2N, I believe there is a rib to right rear of the casting that has to be ground away for the lift cover to fit.(quoted from post at 15:00:53 06/28/18) it has the older double arm that goes down to the pump. The spare set I have is from a newer side mount Distributor 8N. That has the single arm that goes to pump valve
