(quoted from post at 07:06:31 06/27/22) When I bought it, and when the NH dealer supposedly worked on it, it had blue plastic twine in it. I, thinking as old as the baler was, that it might work better with sisal twine in it, so I bought 2 rolls of 9000# twine. Whats your thoughts on my buying plastic twine and trying it?
Ask 5 people, get 8 different answers.
Well tuned knotters should work with any uniform twine. Plastic, sisal, 7200, 9000, etc.
But, as the knotters wear, and get out of adjustment, sometimes you'll find a type and length(really diameter) that works for your knotter.
This is what I've found.
If your twine discs are a little worn, sisal has more friction as it wraps around the bale being made, and it generally pulls harder, especially if you have some water or dew on the hay. You can shorten your bales and use plastic. Or you can replace your twine discs.
If your wiper arm isn't wiping the knot off the billhook, you can try 7200 sisal. It's thick and will get wiped off. Or you can adjust your billhook.
Plastic is generally more uniform, and cheaper.
9000 foot sisal, nowadays, will often vary from ball to ball. You may find thin spots that either break outright, or don't make a knot big enough for the wiper arm to wipe off the billhook.
7200 sisal is the most expensive option. Even the thin spots are generally thick enough work. The only problem with 7200 sisal that I've run into is MY knots. I'm running 7200 sisal right now, we have done 27 loads (about 3200 bales) without a missed knot by the knotter... BUT... the knots that I make to splice the balls together are causing trouble almost every time. I get about 400 bales per bale of twine (2 balls)... and I can expect a broken bale almost every time that my knot pulls through the system. It's a BIG knot, no matter how hard I pull it to tighten it and how closely I cut the tails with my jackknife.
I'm using sisal again because the plastic does not rot...ever. We tilled up a field that we baled for about seven years with plastic twine for a large garden, and you can actually see some of the knot tails in the tilled soil. Seven years of those little one inch tails coming off of every knot and falling on the ground... and you can actually see them.
