(quoted from post at 13:00:29 04/15/19) I'm not against the treatments totally. They are useful in a lot of cases. Mostly I'm interested them for the under-body and frame of a car. A blanket recommendation for them is adding extra cost, hassle, and room for error, especially for a typical DIY'er.
Like many of you I like doing DIY projects, though my tractor is a garden tractor. Along with my home property I own a large lot in a small town about an hour s drive away which needs to be maintained and a second 17 acre lot with lots of bush rock (Canadian Shield) and cabin three hours away. One project was making a loader for my tractor, which obviously required painting. Future projects include a dump trailer and a towable backhoe. I m an expert at industrial painting which got me putting procedures together that can be easily be done by other do it yourselfers.
I familiar with the all the products, basic equipment and supplies needed for painting and where to purchase them. Stuff that another DIY would not have known exists.
Incidentally, I used to live on a farm.[/quote]
I didn't see that you attempted to quote part of my last message.
I can't tell if that is some form of rebuttal or just a brag on your credentials. Trust me -- I'm not trying to lock horns and bicker unnecessarily. I want people to have good information.
You keep mentioning pretreatment as being needed, creating chemical bonds, fixing issues where adhesion was a problem, etc., then pivoting when that view is challenged.
My point of view is:
1. Primer will adhere without treatment and treatment CAN cause issues if not done properly. Sure you outline what you call a sound procedure, but regardless of how sound that procedure is, it is an extra set of steps that introduce room for error and disappointment.
2. Epoxy primer will STILL be a mechanical bond to the treatment is. Any time a urethane is applied and then sanded, the next coat is a mechanical bond. Body filler is a mechanical bond. At some point the "weakest link" argument is relevant.
3. I don't have any reason to believe that paint/epoxy is "porous" in any measure relevant to the application in this forum. Please elaborate "paint on its own will not stop corrosion for any length of time." We are not immersing something with rustoleum in salt water and hoping it is still there in 100 years. The use case is relevant to the procedure.
