Powder Coating
cuttman
Like it or hate it. Have a customer that would like me to get into doing it. I tinker in a shop sandblasting things for the public and done some rims for him. The closest powder coating is 35 miles away. I Been looking at the cost of the small setups. Just looking for opinions. Thanks Gregg
I have a love-hate relationship with it. I have had numerous small pieces done, mostly for my old Fords. I also have a trailer that has it as well as the thrower on my baler. It is relatively fast and cheap, but you have to keep after it on anything that is subject to any scratching or dinging because rust travels very fast under it. The place that I have been getting it done is very reasonable and they sandblast before coating, which makes it EXTREMELY attractive. Now if they were to also epoxy prime first that would be just unbelievably good.
I have had numerous things powercoated. Truck beds-tanks-handrailing-entrance gates-. I have a friend that has a state of the art operation 20 miles from me. They do beautiful work and about any color. Do I like it, no,it just flat does not hold up for the long haul.If you get a ding on it and water gets under it, it will peel off in sheets the size of your hand, even after sandblasting. As for the epoxy,I don't see how you could do this,because of the heat,400Deg for 30 min. will lift almost any primer I have seen.
What the others say is what my experience is - powder coating isn't durable in the long haul. Tends to get moisture underneath, and rust and corrosion soon follow. I have a couple trailer hitches on my cars that really need attention, and will have to come off for refinishing soon. They're probably going to get sandbalsrted and painted with a russt preventative paint - with a brush!
The biggest problem that we face in the custom powder coating world is proper education. I personally understand this as I bought my business with nothing more for knowledge than that of being a customer of the business. I knew nothing. The reason that this happens is the relative price of entry into this business is seen as being fairly low compared to most businesses that are considered to be in the manufacturing field. This perception is also exacerbated by the thought that it is an easy process to do. Both of these misconceptions are just that, misconceptions. The ability to truly understand the nature of the business takes constant education in the powder coating, but also one should have an excellent understanding of metals and also plating processes. This experience I did have from my years in the architectural hardware business selling commercial doors and especially the hardware. My personal passion is also racing of all forms and this taught me an immense amount about metals. This was an excellent base of knowledge to enter the powder coating world. I then had to go to many classes and read everything on powder coating that I could to learn about the technical side of powder coating.
When you call or communicate with a powder coating facility judge the company by how the person on the other end responds. Do they have technical knowledge? Do they speak the language well and have a competent understanding of the language you are speaking or writing? While this may seem like it may be a racial statement it is not. I am simply stating that if the person representing a powder coating facility does not fully understand your needs then your needs will never be met, except by accident.
Unfortunately this is not the case with most business owners and their lack of proper understanding of the powder coating process causes them to make decision based upon economics and not science or fact. It is my job to ascertain from the client what the use of the part is and what the best coating is for that condition. This may include plating style immersion processes in advance of powder coating. It may require base coats, specialty masking considerations, temperature considerations, dwell time in the oven, proper powder choice for the environment in addition to many other variables. This all also must equate to what the clients budget is for the project. We have had many situations where we had to make large and bold type disclosure to a client who will choose price over durability. This is not the powder coaters fault when the coating fails but the powder coating applicator better have the ability to disclose this in advance to avoid an unhappy client and legal ramifications. This is rarely done and this is why clients are unhappy with many powder coaters’. The top of the class powder coater"s charge for their experience and many are in the upper end of manufacturing and unfortunately do not do custom batch work.
We see this so many times and we feel that the disservice that powder coater"s who run their business based on client expectations of an extremely low price for the service, leads to the myth that powder coatings are not effective. Quite the contrary, when applied correctly powder coating is the most durable of the coated or painted finishes bar none. Done incorrectly the powder coated surface will peel, corrode and chip like bad spray paint. The next part that is difficult, from a client’s perspective, is finding the proper powder coater for your application. Like any other service business there are varying degrees of powder coater"s in this world. You may not have a good one in your geographic area, we know that there are several states that do not have good custom powder coater"s due to the demand for these services and the experience of the clients who are purchasing that service. Larger geographic areas tend to have more manufacturing and thus a higher number of powder coater"s who support those industries. You will likely not find a good custom powder coater in a small city, not impossible but unlikely. This is another misconception of those that look at powder coating as a business and say “I have lots of friends with blah blah blah". This ability to coat parts in your garage for your buddies will not result in a successful powder coating venture. If you do not have local manufacturing to assist in the business it will never succeed. This is why it is hard to find quality powder coaters in small cities.
When choosing your powder coater ask to see their operation. Go in back. Are the floors clean? If they are not do you think they can do good work that is not cross color contaminated from a previous job? Do the employees look like they take pride in their appearance and the work that they are doing? Is the lighting adequate to see what the work is that they are doing? Does there seem to be an organized way about the facility? Does the office look organized? If not they may not do a good job of keeping paperwork that may be critical if you need to do that type of work again someday. If you do not take the time to look beyond just the price then don"t blame the powder coater when you do not get what you expected or you experience premature failure of the coating. You are to blame. You chose price or convenience over quality. If you do your job and research the powder coating facility first you will likely have a better chance of getting your expectations met. Again, just like any other service industry you can have the corner tax accountant or you can have Price-Waterhouse, powder coating is no different.
Yes I am blowing my own horn here, unabashedly. But the information that I am imparting to you is good across the country. Use it to find a good coater who really understands his/her trade and you will form a long relationship with them. We have clients from our earliest days of business and I thank those clients for keeping is in business for the past 23 years.
Good hunting.
Scott Andrews
President
Andrews Powder Coating, Inc.
www.powdercoater.com
(quoted from post at 09:02:50 02/09/13) The biggest problem that we face in the custom powder coating world is proper education. I personally understand this as I bought my business with nothing more for knowledge than that of being a customer of the business. I knew nothing. The reason that this happens is the relative price of entry into this business is seen as being fairly low compared to most businesses that are considered to be in the manufacturing field. This perception is also exacerbated by the thought that it is an easy process to do. Both of these misconceptions are just that, misconceptions. The ability to truly understand the nature of the business takes constant education in the powder coating, but also one should have an excellent understanding of metals and also plating processes. This experience I did have from my years in the architectural hardware business selling commercial doors and especially the hardware. My personal passion is also racing of all forms and this taught me an immense amount about metals. This was an excellent base of knowledge to enter the powder coating world. I then had to go to many classes and read everything on powder coating that I could to learn about the technical side of powder coating.
Good hunting.
Scott Andrews
President
Well, Mr Andrews, That is all very nice but 90% is common knowledge and applies to any business, and many of us have run businesses for many years and weren't really in need of business 101. What would be interesting to know is what can keep a powder coated item from rusting under the coating when it gets scratched down to bare metal. As I stated in my first response, I have been happy with the parts that are not subject to scraping or scratching.
For what it's worth I had a set of roll bars powdered coated over 20 years ago for a truck that I used hard daily, always something tied or chained to them rattling around and to this day no rust, never even been waxed.
I paid a lot to get them coated and it has held up beyond my expectations.
I would have thought with all your knowledge in powder coating that you would have covered the fact the powder coating is in fact coating the metal with a plastic material. I would have also thought you would have pointed out the choice of the type of plastic is a big part of how long it will last and in the choice of plastic material is where the metal part is to be used.
Available Materials
Nylon
Abrasion Resistant
Solvent & Alkali Resistant
Low Coefficient to Friction
Machinable
Autoclavable
Vinyl
Good Weatherability
Non-Slip Surface
High Tear Strength
Resists Most Acids and Alkalis
Excellent Electrical Insulation
Polyolefin
Maximum Weatherability
Excellent Adhesion
Flexible
Impact Resistance
Great Chemical Resistance
Epoxy
Super Hard Coating
Maximum Electrical Insulation
Full Range of Colors, Textures and Glosses
Corrosion Resistant
Polyester
UV Resistant
Corrosion Resistant
Polyethylene
Tough, Durable
High Impact Resistance
Good Chemical Resistance
Lowest Cost
Polypropylene
Flexible
Good Impact Resistance
Great Adhesion
Other Materials
Hybrids
Acrylics
and More..
Contact Us For Details!
