Power Block for JD B??????
Anyone know where there is a B power block for sale???? Doesnt matter if it has sleeves, or if cylinder walls are in bad shape. Any help at all is much appreciated
jd b puller new website looks great very impressive, ever made steped head pistons for a allis chalmers c or b, still thinking about putting a crank in my jd b running almost 40 hp now with stock crank but as u know never enough
Thanks for the compliments, still got more to do.
Nobody has asked for that piston for the C, but it shouldn't be a problem. E=mail me some particulars as to pin dia, comp height, bore that you want. We can figure out what the piston needs to look like to get the comp ratio up there to make some power.
Possible, yes. Practical, no...
The piston would be rediculously expensive.
Can you put 720 pistons or something else in there?
Or are you asking if you could build a B piston like an R? If that's the case, you could, but it wouldn't work because you couldn't get the compression where it needs to be.
