power block sleeves ??
8850dave
Does anyone know if sleeves can still be found for M&W Power blocks, I have a power block for a model A tractor and think its a #2
I think Kent is right and there weren't sleeves available
exclusively for them.
Sleeves can be found for just about anything though. Check
with your machine shop.
Like Kent said, power blocks were sold by TSC. There were 3 different blocks for A's and 60's. Your block should have 6-1, 6-2 or 6-3 cast into it. 6-1 for '34 to '47, 6-2 for '47 to '49 and 6-3 for '50 to '52 and 60's.
Sleeves are available according to the posted link.
link
Hi-My neighbor purchased a power block (for a JD 60) and two good JD G pistons (+ .125 ) and sleeved the block to G pistons for his JD 60. He has had no problems but I think he used new studs for the head. He may have used sleeves longer than the block to accommodate the oil rings and put bushings in the pistons to accommodate the piston pins. Tractor has a lot of pep now!!!
