Power block
I have a 60 with a 6-3 power block and it’s getting water in left cylinder. I figure it has a pin hole in cylinder wall and if so is there anywhere to get replacement cylinders for it. Thanks for any info.
More than likely the o-ring is leaking or the block is itself cracked. Not uncommon. We quit machining them because most of them end up with a crack where the sleeve meets the block in the center.
