Power Major hydraulic linkage problem
First one
This message is a reply to an archived post by Ford_Norway on April 16, 2015 at 12:15:06.
The original subject was "Power Major hydraulic linkage problem".
Yes internal leak of hydraulic system.Could be anywhere inside, I've
overhauled mine as I had same issue. found inside more gunk then in a sandpit.
looks like you need to do same. Overhaul kit for it isn't that expensive. But
prepare for some dirty work!
first one, having some hydraulic issues with my power major also.may have to look inside also.where did you get your rebuild kit?are pump rebuild kits available?thanks for any information you can provide.
