actully no, its not the same.. read up on a cetane engine to determine the burning time of the diesel...low cetane diesel will take much longer to burn through on a fire cycle.. so the original method was a specifice cetane engines... although they use forumlas today to issue a cetane level based on analysis of the diesel aromatics, the actual true measurement of cetane is based on a cetane engine. look it up.
anything above 40 is considered ok by most refinery for todays engines... new uls is considered to above 42. once the burn speed or cetane level is high enough, more cetane will do an engine NO GOOD. Once the burn cycle is enough for the top rpm of your engine, adding more will not help.
cetane is based on burning fast enough. This standard is based on a special engine.
octane is based on not eploding based on a heat level.. ie a octane additive means the gas will not fire prematurely in a hot engine.So gas engines with extreame high compression ratio or hotter combustion chambers can benifit from higher octane fuel..HOWEVER.. ONCE ENOUGH OCTANE IS ADDED TO THE FUEL So IT DOES NOT PRE-EXPLODE, ADDING MORE OCTANE WILL DO ABSOLUTLY NOTHING TO IMPROVE PERFORMANCE AND WILL SIMPLY ADD MORE POLUTION. direct fuel injection makes octane problems go away as the fuel is not injected till its time to fire anyway.
cetane high enough means the diesel will burn through it power cycle fast enough to achive the disired rpm. the fuel should burn in 2.4 milliseconds.
ie
The minimum cetane number for diesel fuel
(Grades No. 1 and 2) is 40. The fuel should also
meet a minimum cetane index of 40 or, alternatively,
contain no more than 35 volume percent aromatics.
Some manufacturers may recommend higher
cetane number fuels, so the vehicle or equipment
owner’s manual should always be consulted.
Table 1-1
Results of Inadequate Cetane Number
Poor Ignition Quality
Long Ignition Delay
Abnormal Combustion
Abnormally High Combustion Pressure
Potential Uneven Thrust on Piston / Cylinder
Louder Engine Knock
Excessive Engine Knock & Smoke at Cold Start
while the snake doctors will tell you different, once enough cetane is achieved, adding more will not help at all. also...
the common chemical for increaseing cetane does not work past a certain cetane level. ie you can add an additive and increase cetane from 40 to 42.. then it gets increasing harder to improve it beyond that with additives.
the new hydroprocessing of diesels has improve cetane several points over conventional diesel by removing aromatics so cetane is not a concern.
wiki
In North America, most states adopt ASTM D975 as their diesel fuel standard and the minimum cetane number is set at 40, with typcial values in the 42-45 range. Premium diesels may or may not have higher cetane, depending on the supplier. Premium diesel often use additives to improve CN and lubricity, detergents to clean the fuel injectors and minimize carbon deposits, water dispersants, and other additives depending on geographical and seasonal needs.
To measure the cetane number properly is rather difficult, as it requires burning the fuel in a special, hard-to-find, diesel engine called a Cooperative Fuel Research (CFR) engine, under standard test conditions. The operator of the CFR engine uses a hand-wheel to increase the pressure within the cylinder of the engine until the time between fuel injection and ignition is 2.407ms. The resulting cetane number is then calculated by determining which mixture of cetane (hexadecane) and isocetane (2,2,4,4,6,8,8-heptamethylnonane) will result in the same ignition delay.
chevron site....
Cetane Number, Cetane Index
Cetane number and the cetane index are applicable primarily to gasoil and distillate fuels. The cetane number is a measure of the ignition/combustion quality of the fuel in a diesel engine. The higher the rpm of the engine, the higher the required cetane number.
The cetane number of a fuel is determined in an engine test procedure. The cetane index is a calculated value, based on the density and the distillation of the fuel.
Sooooooooooooo... again.. the speed of the burn cycle... is cetane.. once its fast enough for the top rpm that your going to run, then its high enough.. yes.. cetane does help modern diesels run clean because they delay the injection cycle to help eliminate emissions. When you delay the injection, the fuel has less time to burn, so a higher cetane can help in modern engines with delayed timing and high rpms.
but to a ford 4500, once cetane is above 40 adding more cetane will do NOTHING to improve power, and longevity of the engine.
as in a gas engine, once the octane is high engough that the gas does not pre-explode, adding more octane does nothing..
BUT... higher octane keeps the gas from exploding from a certain temperature till the spark plug set it off. Usually by adding lead or some other chemical.. and once the gas explodes the octane does not add anything to the power, so higher octane aviation gas will not produce anymore power than 85 octane gas. 110 octane aviation fuel will allow you to run higher compression with out pre-ignition or knocking. HIGH OCTANE GASOLENE PRODUCES NO MORE POWER THAN LOW OCTANE GAS. It does allow for higher compression which can produce more power, but the btu's and burn time, an exposive are the same.
back to cetane.. 40 cetane will run a diesel engine up to 5000 rpm and with turbos, higher in race applications... and your ford 4500 should be set for a rpm of less than 2500 rpms. Adding a cetane improver will do nothing for power or starting. Your wasting your money.
And again cetane and octane are not the same. Unless you sell snake oil..
like the test that comsumers org did with moly additives in oil.. once you have enough, adding more did NO good.
a ford 4500 is fine on cetane of 40.. even 38...
