Power shift
Status
Not open for further replies.
rick-HT
I have a FX 22 I lost my power shift the other day. I under stand I might have a broken spring in the bypass valve or the powershift valve. Which one and where are they located?
Does the tractor move at all? I had a problem where it would happen intermittently. Then it just quit moving altogether. I replaces a spring in the valve that is under the center cover next to your rt heel if you are sitting in the seat. Very easy to get out, small snap ring then a 6mm bolt inserted into the middle of the valve (there is a threaded hole) then just pull out. Take it to a clean area and take it apart.
One of the guy's at Hoye told me about this. I just replaced the small spring and it works great again.
Status
