Power Steering Bracket Bolt
wink4000
Looking for bolt that mounts the Power steering bracket to the body of my '68 Ford 4000. Lost one while working and bent the bracket. Fixed bracket but bolt is proving difficult to find. It looks to be 1 3/4" long and the hex is 1 1/8". I figured you all would have some good insight for thread pitch/where to find this sucker!
As near as I can tell, the parts catalog calls for "BOLT, Hex, 3/4" - 10 TPI x 2", Gr 5, Full Thread, CNH part #88557.
The "full thread" "spec." may make it NOT a common hardware store item, worth a check, though.
An option if no FIAT dealer nearby would be #19H3158 from a John Deere dealer.
I would clean the threads in the tractor of oil and grease with BrakeKleen, dry with compressed air, and use Loctite when going back together.
If you can't find them anywhere else, McMaster Carr sells a 5 pack for $7.68.
2" Fully Threaded __ Coarse 1 1/8" 15/32" 120,000 ASME B18.2.1, SAE J429 5 92865A843 7.68
Product Detail
Medium-Strength Grade 5 Steel Hex Head Screw, Zinc-Plated, 3/4"-10 Thread Size, 2" Long
