Power steering hose
Jim Yancey
I have a 850 Ford gas. One of the power steering lines coming from the resovior needs replacing. It is attached without a fitting using just a clamp. Is there a kit to switch that over or do I just cut the end off and clamp it again? Is it a 3/8 or 1/2 inch fitting? Thanks for all the help!
Jim-NC
If you are talking about the return line then just cut the end off and clamp the hose on. The pressure line should have a fitting into the pump
If it is the return line and the hose is questionable, you can replace it with "transmission cooler line" hose from an auto parts store.
If the end is bad the whole hose probably isn't real good. Have a new low preasure hyd hose cut for you at and implement store, or even at NAPA, if you are in a rural area. Reclamp it and you will be fixed for good.
